Leather wrapped coaster
182 opens
71 copies
Steve Knox
Steve Knox
A leather tools inspired coaster. Machined wood wrapped with a thin leather. Milled with assets from the pro design library.
Hard Maple
Hard Maple
6" × 12" × 1/8" Hard Maple
$7.14
$7.14
Cut the wood, Roughing pass + Detail
Using a 1/4" flat end bit, zero off stock and run the roughing pass.
Switch to a 1/32" bit for detail machining.
Cut the wood out to final dimensions. Hand saw, table saw, mitre saw. anything works.
Lightly sand the edges
Lightly sand with 180grit to remove any burs on the wood. I also knocked down the tips of the compass since I was planning to leather wrap.
Apply glue
Using a brush apply a water based glue to the wood ensuring to get into all the crevices.
White PVA glue will work. I used ecostick 1816b but there are many options.
Overlay Leather
lay out a thin piece of leather (I used 0.5mm Italian Buttero)
Starting from the middle press the leather into the details using your fingers.
The leather will stretch and conform as you gradually work it into the coaster.
Optional tools are a bone folder or smooth metal sculpting tool. but anything can work including a popsicle stick or bamboo skewer.
To finish the wrap stretch the leather around the edges and adhere it to the backside.
Trim any excess.
Adhere cork backing as desired. Enjoy!
