2 Player Pinball
561 opens
99 copies
4 comments
Cristiana Felgueiras
They are divided by color and material. You will need to cut almost all the shapes again using plywood or other wooden material of your choice and glue them in layers to make the full thickness of the pieces. Make it at least 5 mm thicker than half the diameter of your ball.
Take a look and have fun making yours!
Open Easel file to see all the pieces needed on the top of the ramps.
My boards ended up with 70 x 53 cm and the overall size of the machine is 140 x 55 x 20 (in the middle where the ramps are higher) cm . I cut the middle angle on the boards' edges to 8º. It seemed to be a good inclination for the balls to roll but you might use a slightly different angle. The steel balls I used are 22mm in diameter.
Aamir Munaf
Very nice and fun work.
Aamir Munaf
Jeff Hunt
HI could you post the cut files as svg if you have them?
Jeff Hunt
Robert Wokaty
oh, this is so nice! My son has a pinball game he loves, but his favorite game is called carpet ball, but I think this could easily be a favorite for him.
Robert Wokaty
John Beckrich
bonjour je suis tres interessé par votre flipper pouvez vous me donner les dimension des raquettes de flip et ou vous avez commander les lanceur de billes est il possible les dimensions des differents obstacles merci
John Beckrich
