Copy of the plaque mounted on the Lunar Module and left on the moon during the Apollo 11 mission. MDF pictured with black paint infill in the engraving and rust oleum aluminum paint applied with a dry foam roller. I have not yet attempted one in aluminum.
** The author's moral rights;
