David, I would do a test cut with 2 pieces and see if the joint is tight. If not scale it up or down and try again. 4/25/19
Andrew Petzold · April 25, 2019
Question. you have a 30x30 peace of plywood but when you go to carving it goes up to 31.5. 1.5 inches off the piece.
Claren Heaton · April 30, 2019
I have never actually made this project. If I was to make it I might scale it down a little or change how the pieces sit. 4/30/19
Andrew Petzold · April 30, 2019
What a great design Andrew! I think that it's really cool making furniture with the cnc. I also love how you fit the pieces. One thing I would suggest is making it a bit bigger if you have enough wood for the job. Other than that it is, again, a great design!
Noah H · October 10, 2020
is it missing the front part of the chair ???
Cody schmidt · February 07, 2021
nvm found it thanks Im new
great design works with .467 birch plywood unmodified if you run as designed leave 1/8th bit in the program but install 1/16th bit into router thanks for the design
Genial
Carlos Roman Vasquez · November 09, 2018
Thanks for the Comment Carlos!!!!! 11/9/2018
Andrew Petzold · November 09, 2018
Will the chair work with .476 birch plywood?
David Peterson · April 25, 2019
robert · March 27, 2021
was the design taken down?
Andrew Smith Milan · September 19, 2022
