Chess Set
484 opens
120 copies
4 comments
Beyond Design
Beyond Design
Chicago, Illinois
A chess/checkers set milled from corian and two color HDPE. The board is reversible for a more traditional grid or a unique pattern to play on
Black Corian®
Black Corian®
Thickness: 1/2 in, Dimensions: 8 in × 12 in, Cut Tolerance: +/- 1/8 in
$76.54
Two-Color HDPE - Black on White
Thickness: 1/4 in, Dimensions: 8 in × 12 in
$6.77
White Corian®
White Corian®
Thickness: 1/2 in, Dimensions: 8 in × 10 in, Color: White, Cut Tolerance: +/- 1/2 in
$83.31
Mill White Corian Pieces
Mill your first set of chess pieces from 1/2" material
Use this EASEL link
Mill Black Corian Pieces
Mill your second set of chess pieces from 1/2" material
Use this EASEL link
Etch grid into HDPE
Use a 1/32" bit to etch a checkers grid into one side of the HDPE
Use this EASEL link
Cut Reverse side of HDPE
flip HDPE sheet, being careful to align it in the correct position. Etch the chess pattern with a 1/32" bit and cut the profile
Use this EASEL link
Glue and sand pieces
Glue pieces into stacks to create the taller pieces, leaving single height parts as pawns. Sand the sides smooth once completed
Sam Sonta
I wanna that
Sam Sonta
Tyiesha Gainey Crafton
How did you cut out the chess pieces? What was the bit size?
Fred Housel
Thanks for sharing! I modified your designs to make a larger set from cherry and purpleheart. Love it. If I were to do it again I think I would try etching the grid after cutting the profile. Also, I'd recommend to anyone making this to cut the profile with a 1/16" or larger bit, not a 1/32".
Fred Housel
Boyd Wold
The links for the chess board do not work. Are they still in Easel?
Boyd Wold
