Coffee Wall Art with Changable Color Insert
273 opens
119 copies
Joel North
Joel North
Insert your favorite paper into the slot in the back to change the look of this wall art. Switch it out as often as you like to match any occasion or decor. This wall art is so fresh you can almost smell the coffee!
Gorilla Wood Glue
Gorilla Wood Glue
Gorilla Wood Glue - 4 oz
6" × 12" × 1/2" Walnut
6" × 12" × 1/8" Walnut
$9.09
$9.09
Plane
3 minutes
Start this project off by buying or planing sheets of material to .375 and 1.25.
Dimension
Cut both pieces of material to 6 inches by 6 inches.
Mount the Work Piece
3 minutes
Mount the thicker piece of wood to the X-Carve using double sided tape and set your zeros.
Cut
36 minutes
In Easel, run the work piece that is labeled “body.”
Mount the 2nd Work Piece
3 minutes
Mount the thinner piece of wood to the X-Carve using double sided tape and set your zeros.
Cut
4 minutes
In Easel, run the work piece that is labeled “Back.”
Sand
Sand both pieces where needed.
Apply Finish
Apply your favorite finish. I suggest a spray on poly for this one.
9
Assemble
4 minutes
Apply wood glue to the three ledges. Attach both pieces together using clamps, making sure even clamping pressure is applied.
10
Select a color
Use your favorite paper to add a pop of color to the art piece!
Paper should be cut to slightly less than 5 by 5 inches with the bottom corners rounded off. I suggest picking a few of your favorite colors and cutting them all to size at the same time. That way you can store them together in the slot and switch them out on a whim.
11
Hang and Enjoy
Now that all of your hard work is done, select a choice spot on the wall and use either a screw or nail to hang your project. Once it is hung, feel free to switch out the colors as the seasons change or for whatever occasion arises.
Made one? Log in to add yours
