Cog. Transfer that movement!
47 opens
15 copies
Kilted Woodsman
Kilted Woodsman
How to make a old looking cog. Larger versions have been found through out Europe as far back as the Medieval era (12 Cent). Most widely known use for cogs have been in Windmills(both for grain and sawmills).
The limit of these are only limited by your imagination.
Soft Maple - Hardwood Type
Setup and CNC
Check and setup your Cut Settings. I run my machine a bit fast.
Just know the material your cutting and its limitations.
A no-brainer… I know.
Sand it.
8 minutes
Just give the projections a good sanding, rounding the long 90s a bit.
Make sure to get the burs off the cutouts for the rod.
The rest depends on how picky you are.
Glue it up!
For the projections, i just place a dab of glue on the cog cutout (for the projection). A dab on the back of the cutout and the outermost corners.
I let the projections hang over the back of the cog about 1/16" and place the back of cog on the workbench. Pressing the parts of the cog thats around the projection firmly down to allow the projection to self level. (Good enough for me.)
The rod couplers (Cant think of the correct name for these guys…) just need glue on the back and placed. I didn’t have a 3/4" rod for this set, so i just aligned it by sight and feel.
Undoubtedly the best way to get these couplers aligned correctly is to have that rod in place when gluing.
Finished
Now you need a frame for the cogs and something to move it.
Ideas for generating movement…
Water wheel.
Windmill.
More?…..
