Corian Tilt Maze
275 opens
75 copies
2 comments
Jules Woodard
Jules Woodard
Chicago
Brighten up your coffee table with this colorful corian maze. With six ways to win it’s the perfect little distraction for your brain.
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/16 in, Material Type: Cast
$2.99
Neon Pink Acrylic Sheet
White Corian®
White Corian®
Thickness: 1/2 in, Dimensions: 8 in × 12 in, Cut Tolerance: +/- 1/8 in
$2.99
Carve
120 minutes
Carve all 3 work pieces of the Easel file using a 1/8" bit.
Color
Use neon markers to color the inside of the maze to give it more dimension. I used a different color for each finish point. If you want a clean white maze skip this step.
Assemble
Drop in a 5/32" ball before sealing it up – I found one at Home Depot.
I used double sided tape to secure all 3 pieces of my maze. You could also use clear glue for a more durable finish.
