Cutter Storage Board
147 opens
53 copies
Mitch Peacock
Mitch Peacock
Published On
August 22, 2018
Keep your machine's cutters safe and easy to locate, by making this storage board. It also has a slot for the collet wrench, to save it getting lost. The design uses Easel's new Drill Holes feature, which makes boring holes the same diameter as the cutter quick and easy to include.
Prepare Blank
Cut the storage board blank out 13"x4½", from a 5/8" or 3/4" thick piece of plywood Apply a finish to the board, such as a colored wax (as I used), shellac, or paint, and allow to dry Secure on the machine
Estimated time: 10 minutes
Cut 1/8" Holes on Machine
Select the first 'workpiece' in Easel, and carve it with the 1/8" straight bit
Cut Text on Machine
Select the third 'workpiece' in Easel, and carve it with the 1/16" downcut bit Of course you may alter the name, BITSTORE, to anything you wish
Estimated time: 2 minutes
Cut 1/4" Holes on Machine
Select the second 'workpiece' in Easel, and carve it with the 1/4" straight bit
Tidy Up and Use
Lightly sand any frayed edges from the carve Insert your most used selection of cutters, and the collet wrench
"Video":https://youtu.be/aU0Mx5I7-yY
