Cuts in about 4 Minutes. A wood Key fob that also holds your phone for viewing videos while on a long plane ride to the West Coast. Fob is small enough to toss in your pocket or bag, and not take up prime real estate when traveling.
** The author's moral rights;
After sanding and protecting the wood with Paste wax, I used a Key ring, and three 4.5mm screw posts to secure all the pieces together.
Estimated time: 5 minutes
Any chance you can make this public?
Jon Conner
Hi Jon, the project is public, just click on the "open in easel" link. thanks, Katrina
Kat Harris Parker
Still says its not public. Would love to have it if possible.
Dayle Hall
I checked with Inventables and the project is public. Try this link and see if it opens for you: https://easel.inventables.com/projects/Y-YTvDRapwjQ9FN7RsPRAA
Jon Conner
Kat Harris Parker
Dayle Hall
Kat Harris Parker
