Red Stone Lamp
196 opens
48 copies
4 comments
Fernando Romero
Fernando Romero
Published On
November 26, 2015
Plywood red stone lamp. 11.5" x11.5" x 11.5".
Panel Construction
Cut 11.5" x 11.5" squares out of 3/8" or 1/2" plywood. Cut 45º chamfer around edge of the square. Mill holes on side panels (qty. 4) Mill holes on special panel for light switch.
Estimated time: 200 minutes
Assembly
Glue five panels together to form a cube. (exclude the bottom panel, which will be fastened with screws) Use reinforcing wood blocks on interior to add rigidity to the cube sides. Cut five polycarbonate (lexan) windows. Glue red and then yellow tissue paper over exterior side of lexan windows.
Finish of paint five sided cube and bottom panel with back paint or stain.
Fasten lexan panels to interior of cube.
Attach light fixture with dimmable LED bulb. Connect light switch (dimmer)
Fasten bottom panel with screws.
Derek D
Are you going to share your easel files? Thanks
Derek D · December 03, 2015
Fernando Romero
Derek, The file for a regular side panel is attached to the project. You can use the same file to generate the panel that holds the light switch. Simply select one of the profiles and change the depth to zero. Then you can manually cut the hole for the switch depending on the type you choose.
Fernando Romero · December 04, 2015
Cyrus Rich
Please share the file
Cyrus Rich · June 25, 2017
Zach or Sarah Harner
can we get a public file for this? thanks!
Zach or Sarah Harner · July 19, 2018
