Shapeoko Dual Drive Kit
Edward Ford
Edward Ford
All parts required to change your Shapeoko from a single gantry drive to a dual drive.
Adding a second drive allows you to cut harder materials, such as aluminum and hardwoods, along with giving you more accurate results on all materials.
Flat Washer
Flat Washer
Finish: Zinc Plated, Dimensions: I.D: 3.2mm; O.D: 7mm, Quantity: 10
$2.00
Flat Washer
Flat Washer
$2.99
Hex Nuts
Hex Nuts
Mending Bracket
Mending Bracket (×2)
Length: 2.0 in, Width: 0.5 in, Type: Bracket, Bracket Type: Mending
MXL Belting - Open Ended
MXL Belting - Open Ended (×2)
Pitch: 0.08 in, Width: 0.25 in, Length: 12 in (shipped uncut if more than 1' is ordered)
Nylon Natural Color Spacer (M5)
Length: .25 in, O.D.: .312 in
Plastic MXL Pulley - Dual Flange
Bore: 5 mm, Teeth: 18
Red Cable Tie
Red Cable Tie
Type: Cable Ties, Length: 4 in, Quantity: 10, Tensile Strength: 18, Color: Red
$1.00
Smooth Idler Wheel
Smooth Idler Wheel (×2)
Qty: 1 kit don't use, Belt Width: 6.35 mm
Length: 6mm - 2012 - 2019, Quantity: 10, Thread Size: M3
Length: 30mm, Quantity: 10, Thread Size: M5
Stepper Motor - NEMA 17
Lead Time: In stock, Holding Torque: 62 oz/in
Stepper Motor Cable
Stepper Motor Cable (×3)
Length: 1 ft, Category: Accessory, Type: Cable
Terminal Block
Terminal Block
Positions: Terminal Block 4
$4.99
$10.98
Introduction
The Shapeoko dual drive upgrade kit allows your machine to cut harder materials at a faster feed rate by evenly distributing the power across the gantry.
Identify the required parts
In this step we’ll look at each of the parts required to complete the upgrade.
Removing the Gantry from the frame
In this step we’ll remove the gantry from the machine’s main frame. Once the gantry is removed, we can easily add our upgrade parts.
Attach the Stepper Motors
In this step we’ll use our four M3x6mm socket head cap screws to mount the stepper motor to the motor mount plate.
Attach Smooth Idlers and Pulley
In this step we will attach the two smooth idlers to the motor mount plate, and the pulley onto the stepper motor shaft.
Final Assembly
In this step we’ll put the gantry back on the machine’s frame, string the new belt, and talk about electrical wiring options.
Made one? Log in to add yours
Ed Powers
Great explanation. Detailed and easy to understand. Any chance you could either show the wiring process at the end, or at least take some photos of the configuration once wired? As a rookie, I worry about doing damage to the motors or gantry with incorrect wiring... Thank you!
Ed Powers
Scott Orlando
Do you have the parts list for the duel gantry setup?
Scott Orlando
