Golden ratio wood clamp set.
Materials:
1. Home Depot 0.5" X 3.5" X 36" Oakwood1
2. Cap Screw M5-0.8 X 50 mm Metric2
3. M5 washer2
4. M5 nut2
5. 220 sandpaper *1
6. Wood oil *1
** The author's moral rights;
