Woodworking Mallet
691 opens
287 copies
958 downloads 1 comment
Travis Lucia
Travis Lucia
A traditional style woodworking mallet is a great addition to any shop! This project allows you to quickly carve and customize your own personal woodworking mallet.
Cherry Wood
Cherry Wood (×2)
6" × 12" × 1/2" Cherry Wood
$17.72
Hard Maple
Hard Maple (×2)
6" × 12" × 1/2" Hard Maple
$17.72
Add to Cart
$35.44
Mallet.svg
Materials and Tools
Materials:
-1/2" Hardwood (I used hard maple and cherry, both are available from inventables)
-Wood glue (Tightbond 2 is my preference)
-Finish (Finish is optional but will greatly enhance the look of your finished product, I used spray on polyurethane)
Tools:
X-carve
Bandsaw (Optional)
Random Orbit Sander
Open the Project in Easel
Open the project in easel and customize it to your liking with your initials or a simple design!
Set up your material and secure it tightly to the wasteboard.
Carve!
I used an 1/8" 2 flute straight bit from bosch.
Layout
2 minutes
Layout your pieces, clamps and get your glue ready. It helps to have a silicone glue brush for spreading the glue around the pieces evenly but this can be achieved using your finger or a paint brush.
Glue
Add glue to the faces that will be joined together spreading it out to ensure total coverage of all surfaces.
Clamp
3 minutes
Quickly add clamps to your glued mallet, the more clamps the better! Check the surfaces when tightening clamps to ensure things are staying even and flush.
Bandsaw (optional)
If you have a bandsaw and your pieces shifted slightly the bandsaw can be an excellent option for cleaning up and making faces perfectly even.
Shaping and Sanding
Shaping the handle, smoothing edges and faces as well as adding a customized feel can all be accomplished using a random orbit sander a clamp and a low grit sanding paper.
9
Finishing
Finish is an optional step but will greatly enhance the look of your finished product as well as add life to the tool. I used 3 coats of a simple and quick spray on polyurethane sanding between coats with 320 grit sandpaper.
Made one? Log in to add yours
Johnathan Branson
A good idea on this might be to add some dowel holes and that would make alignment in glue up a little easier. Think ill try that when i cut this one
Johnathan Branson
