Black Anodized Aluminum Sheets
Black Anodized Aluminum Sheets: Complete Product Details and Specs
Perfect for Halloween!
Anodizing is a process used to increase the thickness of the natural oxide layer on the surface of metal parts. It increases corrosion and wear resistance, and during the process the anodized aluminum surface can be dyed into many different colors.
The front of each sheet has a pristine finish; the back may contain a slight groove spanning the width of the sheet, or minor blemishes. These imperfections are caused by the manufacturing process and will only be found on one side of the sheet, if at all. Coloration may vary from batch to batch.
- Color: Black
- Form: Sheet
- Material: Aluminum
- Surface Finish: Anodized
