SKU# 30238-02 (Single)
SKU# 30238-06 (10 Pack)
The spiral upcut bits pull chips from the cutting surface upwards, leaving a flat bottomed pocket. This provides accurate cuts without chatter in the plastic because the chips are being evacuated away from the cutting edges. This bit is not recommended for wood because it pulls the wood fibers causing tear out.
- Cutting Length: 0.87 in
- Overall Length: 1.77 in
- Best for Cutting: Corian, aluminum, plastic, linoleum
