NaN of -Infinity
Fein Multimaster MM 300 Plus Quickstart
Regular price $55.00 USD
Regular price Sale price $55.00 USD
  • Self-supporting motor with vibration decoupling for outstanding vibration and noise reduction.
  • Very powerful 350 Watt FEIN high-performance motor for optimal cutting speeds and maximum work progress.
  • Highest quality and stability due to metal gear case and consistent use of ball or needle bearings.
  • Convenient QuickIN rapid-clamping system.
  • Electronic speed control with tacho generator for constant speed, even under load.
  • Integrated interface for mounting additional system accessories.
  • Softgrip zone provides optimal handling.
  • StarlockPlus tool mount with outstanding torque transfer, fits all Starlock and StarlockPlus accessories.
  • Wide selection of accessories available for all applications.
Included
  • 1 universal E-Cut saw blade 1-3/4 in (44 mm) (type 152)
  • 1 E-Cut Precision BIM saw blade (1-3/8 35 in[mm])
  • 1 E-Cut Standard saw blade, curved (2 50 in[mm])
  • 1 perforated sanding pad
  • 20 perforated sanding sheets (5 each of grits 60, 80, 120, 180)
  • 1 tool case
  • Power consumption: 350 W
  • Oscillations: 11,000 - 20,000 opm
  • Tool mount: StarlockPlus
  • Tool change: QuickIN
  • Range: 2 x 1,6°
  • Cable with plug: 16.4 [5] ft[m]
  • Weight: 3.09 [1.40] lbs[kg]
