X-Carve 2015 to 2016 Update Kit
Make your X-Carve stronger, smarter, and more reliable with this update kit. Backwards-compatible with all X-Carve machines shipped before September 2016.
The X-Carve update kit is available in both 500mm and 1000mm sizes.
Each kit contains:
- X-Controller
- Wide MakerSlide
- Side Board
- Z-Probe
- Stepper Motor Cable
- X-Carve sticker for the MakerSlide
The stepper motor cable is included in case you would like to take advantage of the X-Controller’s extra stepper driver. That part of the update process is a “nice to have” option, not a necessity. If you don’t need to use the extra driver, just ignore the stepper motor cable. More information about rewiring the machine to use all four stepper drivers is available at the X-Controller Usage Instructions under “Option 2.”
NOTE: A 500mm machine cannot be updated to a 1000mm machine without additional parts.
