X-Carve Upgrade: 9 mm Belt and Motor Kit
With this upgrade kit, your X-Carve is just 90 minutes away from higher material removal rates, cutting speeds, and reliability. Replaces the 6mm wide 2GT belts with 9mm wide 3GT belts and stepper motors with 50% more torque.
NOTE: 2015 Model X-Carve Machines (purchased before Sept. 2016) will need additional components to be compatible. The updated X, Y1, Y2, and Z stepper motor cable assemblies are needed to connect to the motors. The X-Controller Kit is necessary to run the upgrades to their full potential.
