PRO LEVEL CNC MACHINES
BRING YOUR IDEAS TO LIFE with easy to learn CNC for any size shop
Starting at $167/mo or 0% APR with Affirm
David B.
"Very impressed with the fact that, for someone new to CNC machines with no experience and prior knowledge... [I] can order this machine and be up & running within a week."
Todd M.
"The machine was well built and assembled easily. We were making real parts on day one."
Benjamin S.
"The machine is a MACHINE - so solidly built. The instructions were great. The user interface is intuitive."
A PRO LEVEL CNC MACHINE BUILT TO LAST
PICK YOUR PRO
EASILY GO FROM CUSTOM DESIGN TO PRODUCTION
DESIGN
Use our CNC software to bring your vision to life. Use intuitive controls to drag, drop & design your products.
CUT
Our software optimizes your design for production and controls the X-CARVE PRO to produce parts quickly and accurately.
SCALE
X-Carve Pro CNC system speeds up production so you can take on more jobs and get them out faster.
WHAT CAN YOU MAKE WITH THE X-CARVE PRO CNC MACHINE?
AND MORE...
SAVE TIME AND MONEY
No more skilled labor
No need to source and hire specialized operators. Our CNC system is so easy anyone can design and cut products.
Return on Investment
We offer both personal and business financing options. Spread out costs of the X-Carve Pro CNC with affordable monthly payments as your business grows and generates more revenue.
Reduce costly errors
5.5-ft. rigid aluminum gantry houses 25mm ball screws for accuracy to the width of a human hair.
WORLD’S EASIEST
CAD/CAM SOFTWARE
WORLD’S EASIEST
CAD/CAM SOFTWARE
for X-Carve Pro
DRAG AND DROP DESIGNING
EASEL's easy-to-use platform lets you design and connect seamlessly to your CNC machine. It’s the only software your business needs to design, import, cut, and share—all in minutes!
Now introducing 3D Carving: with the click of a button, import STL files and watch 3D designs come to life.
Carve Big With A
Small Footprint
Most of the time, shops don't use the full carvable area of their 4x8' machines, which means a lot of wasted floor space. Easel Pro's Tiling feature lets you design as big as you need, then tells your X-Carve Pro to carve section by section–seamlessly.
